DI-158U "Forgets" Default Setup
i may have originally put this in the wrong forum (DATAQ Hardware).
Randomly, the DATAQ model DI-158U will "forget" the default setup. Opening a "reference file" does not transfer the settings back to the way they were set up. This is causing us to redo the settings when the program is opened. Sometimes, opening WinDaq will open correctly with the user defined settings. Other times, it opens with the out-of-the-box settings.
How can we make our settings stick?
