DI-2108 writing files with UTC timestamps in stand alone mode
I use a DI-2108 in stand alone mode sometimes and I usually set the clock from the PC clock periodically. I noticed that then timestamps on the files written to the USB drive are in UTC time, but then when I use WinDaq to update the file it will change the time to local system time (PST in my case). This is confusing. Is there a way to tell the DI-2108 to use local time timestamps and not UTC time when it creates the files on the USB drive?
