DI-710 Power jack
DI-710 Power jack
Hey
I just acquired a DI-710-EL device and the plan is to use it combination with a test bench in a fairly rural environment. The plan was to power it with 24VDC source which should be fine according to the data sheet, the only problem is that I need to acquire a power connection that fits. Does anyone know the exact dimensions for the DI-710 power input jack?
Sincerely,
PN
