Greetings. I am trying to setup Windaq to auto-start when my PC boots up. I'm having decent success following the post linked below, with one exception. When Windaq launches, I get a popup telling me "sample rate [per channel] was raised to 0.0762 (minimum sample rate)." However, the data file I'm using to provide startup parameters has 4 channels enabled, a minimum sample rate of 0.00305/channel and a max of 100/channel. My desired rate is 0.016667 (1 sample per minute).
From the blog:
"[-F[d:path]setupfile] is an data file (including drive and path) from which parameters such as the number of channels, sample rate and scaling are ported."
My setup file (startupparams.wdq) has the sample rates mentioned above. I can launch this file manually and maintain settings I want, but when it launches using the Windows batch file, it wants to reset the sample rate.
Any suggestions? Is it something to do with the codaspar file?
Thank you in advance.
